Activity Forums Adobe After Effects How to maintain Aspect Ratio between Photoshop/After Effects
  • How to maintain Aspect Ratio between Photoshop/After Effects
    Posted by Justin Von konsky on June 17, 2008 at 6:24 am
    Sorry if this is a repeated question. I need to animate a logo created in photoshop. However when I bring the logo into After Effects [NTSC Widescreen (1.2)] the logo’s quality degrades. When I toggle the aspect correction button the logo’s quality improves, but everything squeezes. Does anyone know how to keep the logo’s quality and the correct aspect ratio? Thank you
    Peter Van der zee replied 18 years, 2 months ago 3 Members · 2 Replies
  • Filip Vandueren
    June 17, 2008 at 8:27 am
    That’s just what pixel aspect ratio does:
    it has to throw away pixels to get to 720 pixels wide.
    A TV-screen will stretch it back out, but it will be interpolated (softer)
    Unfortunately, After effects when ‘previewing” that stretch (using Pixel aspect compensation) utlies “nearest neighbour sampling” to speed things up, so it looks hideous on your monitor.
    On TV, it will look a bit beter.
  • Peter Van der zee
    June 18, 2008 at 11:19 am
    Don’t worry about the squeezing,
    the actual output file will be like that.
    (but with a message to the reproducer to strech it out again)
    You’ll get used to watch squeezed images if you want to look at the quality
    and to watch poor quality when your working on the compositing
    http://www.zeemotion.com
