Activity Forums Apple Final Cut Pro Legacy How to lose unwanted audio tracks
  • How to lose unwanted audio tracks
    Posted by Viktor David on February 18, 2016 at 3:16 am
    Hello,
    I am a shooter. Occasionally, under protest, I have to cut my material on the field. Sometimes, I have to do it really fast. And that’s where I am dealing with the issue like that:
    My camera, SONY FS7 records 8 channels of audio. I only need first 2. Now, every clip imported into FCP7 has 8 channels. So, i have to place them onto the timeline, unsync them, delete unwanted tracks, sync them again. It slows down the process tremendously. I know there’s a way to lose all unwanted audio tracks in the editor window. Or possibly even while importing. Please, help.
    Vic
    Studio 7NY
    G5 Dual 2 Ghz, Leopard, FCP Studio 2, Blackmagic HD, ATTO UL4D, MOTU V3HD
    Viktor David replied 10 years, 7 months ago 4 Members · 4 Replies
  • Mark Suszko
    February 18, 2016 at 2:42 pm
    User prefs, timeline options, look to the right hand side and pick the default number of audio tracks you want.
  • Shane Ross
    February 18, 2016 at 5:08 pm
    Do you use Log and Transfer to bring in the footage? In the audio tab of that you can tell FCP to only import the tracks you want.
    Shane
    Little Frog Post
  • Nick Meyers
    February 19, 2016 at 1:59 am
    what Shane says
    OR,
    if you really want to get rid of those empty tracks for good from the master file
    use an app called QTChange
    https://www.videotoolshed.com/product/42/qtchange
    “i have to place them onto the timeline, unsync them, delete unwanted tracks, sync them again. It slows down the process tremendously”
    there is a quicker way:
    lock the picture,
    lock the 1st 2 audio tracks,
    select all, delete.
    then…
    copy all in the timeline
    delete the original clips from the browser,
    copy the 2tk clips into a new bin.
    now you have 2tk master clips, and match framing should bring up the 2tk version.
    nick
  • Viktor David
    February 19, 2016 at 7:46 am
    Thank you, all. I am importing XDCAM files. So, someone suggested in preferences to check “Import only 1/2. that’s exactly what i needed. Thank you for your help!
    Studio 7NY
