Activity Forums Adobe After Effects How to loopOut(“pingpong”) with a variable
  • How to loopOut(“pingpong”) with a variable
    Posted by Bia Lemos on July 9, 2020 at 11:52 pm
    hey guys
    i’m new to expressions in after effects. but i know how to use loopOut() by creating the keyframes i need. what i want to do now is to apply a loop in the X scale which is already changing throughout my animation.
    here is the thing: i have an object that changes its size, growing proportionally in the X and Y, but sometimes the X is a negative number (so the image flips).
    while it does that, i’d also like it to changes its X size back and forth in a loop.
    adding 3, going back to its actual size, and then subtracting 3.
    for example: (-97, 100) > (-100,100) > (-103,100) > (-100,100) > (-97,100) and so forth
    that being said, i need to the X value to be a variable. so it will loop the X scale automatically according to the X,Y scale animation i have already done manually with keyframes. (and if the value on X is negative, it has to stay negative)
    i do have experience with coding but not with javascript.
    idk what to do. any ideas?
    thanks xoxo
    Robert Müller replied 6 years, 1 month ago 2 Members · 1 Reply
  • Robert Müller
    July 10, 2020 at 8:40 am
    You could use sine for this, like this maybe?
    spd = 5;
    fct = 3;
    s=Math.sin(time*spd)*3;
    [value[0]+s,value[1]]
    “spd” is the speed of the sine function and “fct” is by how much the value will change.
