Activity Forums Adobe After Effects how to loop video footage or precomp?
  • how to loop video footage or precomp?
    Posted by Eugene Hooper on October 2, 2009 at 10:53 am
    Hey guys,
    Just wandering whether it’s possible to make an imported video footage or a comp continuously loop playback? Is the only possible way making duplicates of your clip and adding it at the end of the clip on a new layer?
    Would love to know if alternatives exist.
    Cheers, Eugene
    Macbook 2.4Ghz Intel Core 2 Duo, 4GB RAM
    Todd Kopriva replied 16 years, 11 months ago 4 Members · 3 Replies
  • Joseph W. bourke
    October 2, 2009 at 1:37 pm
    Hi Eugene –
    While dissolving clips end to end will do the trick (if you know the max amount of time you need the clip to play), there’s another way. It’s called a dissolve loop. You split your clip in the middle, swap the two pieces end for end, and put a dissolve where the two former ends were. You will need to tweak how long the dissolve is depending on whether it looks better with a quick, or slow dissolve. That’s a content issue, subject to the editor’s taste.
    It works well with most footage, especially when the dissolve loops are used as background pieces. You can set up a template in After Effects specifically for this, then just drop your footage into it and render. Have fun!
    Joe Bourke
    Creative Director / Multimedia Specialist
    B&S Exhibits and Multimedia
    bs-exhibits.com
  • Chris Brearley
    October 2, 2009 at 1:46 pm
    Right-click on the footage in the project window and go to Interpret Footage > Main. Down the bottom in ‘Other options’ is a box where you can set how many times you want your footage to loop.
  • Todd Kopriva
    October 2, 2009 at 3:25 pm
    See “Loop a footage item”.
    I found this using this After Effects Community Help search for the terms in your subject line for this thread.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
