Activity Forums Adobe Premiere Pro How to loop clips
  • How to loop clips
    Posted by Navarro Parker on January 3, 2013 at 12:21 am
    Is there a way to easily loop a clip? (Other than placing multiple copies end-to-end in a nested sequence)
    In AE, I can turn on time remapping, add a loop_out() expression and drag the layer’s length to infinity. Anything like that in PPro?
    Quincy Logan replied 9 years, 4 months ago 6 Members · 5 Replies
  • Ann Bens
    January 3, 2013 at 9:31 am
    There is a loop function in Pro but that is only for viewing.
    Click on the wrench.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Alex Udell
    January 4, 2013 at 2:17 am
    no….
    but you could send the clip to AE as a dynamic linked comp and do the loop as you describe in your post…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Rune Abro
    February 20, 2014 at 11:35 am
    This is really a missing feature imo.. I assume that doing the dynamic link rountrip will add to system load?
    I need to be able to add film grain to my footage in premiere.
    The best looking film grain I have achieved so far is by placing a layer of scanned grain footage above my other layers and blend it using overlay at 35& opacity. I like however, to be able to adjust the amount (opacity) to my liking, and this is tedious to do if working with multiple instances of the noise footage on one layer.. Am I missing something?
    Daylight broke me loose and brought me back
  • Gabor gary Szabo
    April 29, 2014 at 10:33 pm
    For the grain you can make an adjustment layer and download presets like Jarles’ Presets found online and place it above your clips in the timeline and lower the opacity accordingly. That way you don’t have to adjust each clip
  • Quincy Logan
    April 25, 2017 at 3:34 pm
    I found the answer on YouTube:
    You need to reveal the Loop button with the ‘+’ button to the lower right of your main Program viewer. Then set your Mark In / Out points on the timeline to the clip you want to loop.
