Activity Forums Adobe After Effects Expressions How to loop a linear function
  • How to loop a linear function
    Posted by Kyle Maven on June 10, 2021 at 11:09 pm
    I have an image of a car tire rim. The lighting is different on all the “spokes”. Ultimately, I want the tire to look like the lighting is the same as it rotates. I am trying to set it up so that when I rotate the tire, the opacity of a duplicated layer, that is rotated at -72degrees (there are 5 rims, 5/360=72), changes from 0 to 100 and then loops as the rotation of the layer continues. I am not sure if this is possible or if I am just not using the right combination of expressions in the correct order. This is what I have >
    s = transform.rotation;
    loopOut(“cycle”);
    linear(s, -72, 0, 0, 100)
    I hope this makes sense and that I provided as much information as I could. Thanks in advance!!!
    Arne Münch replied 5 years, 2 months ago 2 Members · 1 Reply
  • Arne Münch
    June 15, 2021 at 12:19 pm
    i think instead of the loop function you need a modulo.
    so replace the loopout with something like
    s= s%72 – 72
    not exacly sure what you really want but this may help
