Activity › Forums › Adobe After Effects › How to loop 2 PNG frames in AfterEffects?
Posted by Nikola Tomic on July 16, 2014 at 6:15 amHello guys
I am trying to loop 2 PNG frames like in attached example / printscreen through entire timeline?:
I’ve tried TimeRemap but it does not loop frames…
Nikola Tomic replied 12 years, 2 months ago 3 Members · 4 Replies -
John Cuevas
July 16, 2014 at 1:03 pmIs it a single frame, you are trying to loop? Can’t you just make it a freeze frame then?
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Nikola Tomic
July 16, 2014 at 1:14 pmNope it has two different frames. I want to loop 2 different images/pictures. Or 4, whatever.
Brian Charles
July 16, 2014 at 1:43 pmAdd another KF for the loop. So if KF 1 is frame 0, and KF 2 is frame 1, KF 3 repeats frame 0.
See:
Nikola Tomic
July 16, 2014 at 11:23 pmWell to me interpret footage is not selectable here. It works only on short videos or gif animatons. Not for composition I create here… 🙁 Later I will try to understand this excellent example that actually works attached in previous email 🙂 Thank you guys very much!!
