Activity › Forums › Apple Final Cut Pro Legacy › How to Log and Transfer (SONY EX1) to External Hard Drive?
  • How to Log and Transfer (SONY EX1) to External Hard Drive?
    Posted by Daniel Grixti on July 28, 2010 at 5:00 pm
    Hi there,
    I have been given some EX1 footage to use in an edit and have downloaded the Log And Transfer utility from the Sony website.
    I have added the folder containing the footage but when I go to add the clips to the queue it seems as if the destination is the hard drive on my laptop. So what I need to know is how to change the destination to my external hard drive so that when I add the clips to the queue the resulting files will be transfered to my external hard drive, ready to be edited in FCP.
    Dan
    Doug Beal replied 16 years, 2 months ago 3 Members · 4 Replies
  • Andrew Kimery
    July 28, 2010 at 6:09 pm
    Launch the XDCAM Xfer software, go to Preferences, then Import and you set your destination there.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Doug Beal
    July 28, 2010 at 6:11 pm
    Look in XDCam xfer >preferences>Import and hit the choose button for location
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Daniel Grixti
    July 29, 2010 at 5:27 pm
    I’m still kind of confused as to how to do this.
    I am in Final Cut Pro. I go file > log and transfer > then click the import folder icon.
    I can import my EX1 footage but then when I try and add the clips to the queue I am restricted by my hard drive space. This is why I want to send the clips to my external hard drive.
    If there is no way to change the destination here then could someone give me a walkthrough on how to use the stand alone application?
  • Doug Beal
    July 29, 2010 at 7:24 pm
    No you first install the XDCam packages that allow you to read the card, and the XDCam Xfer software then you go file>import>xdcam transfer.
    on some stations it opens in the background and you need to go to the dock to bring it foreground.
    Inside the XDCam Xfer software under preferences>Import is where you set the destination drive.
    The software is here
    https://www.servicesplus.sel.sony.com/sony-software-model-PDZKP1.aspx
    Doug Beal
    Editor / Engineer
    Nashville TN
