Activity Forums Adobe After Effects How to load my presets from ScriptUiPanel with extended Script?
  • How to load my presets from ScriptUiPanel with extended Script?
    Posted by Vahab San on May 5, 2017 at 8:25 am
    Hi all
    I’ve made few presets and copied them in “ScriptUI Panels\Pr\C-Sh\fxs\Sample_01”.
    Now I want to load and apply them to the layer I made via extended Script.
    I’ve tried to get the path by $.getenv(); but it seems I can’t find the right value for the getenv(); and it keeps turning null as result.
    How can I access the “ScriptUI Panels” folder in away that if I run my script on another pc it returns the same path.
    here is the actual code I’ve typed :
    var Preset = File($.getenv()+”\\Scripts\\ScriptUI Panels\\Pr\\C-Sh\\fxs\\Sample_0″+i);
    and here is the result I’m getting:
    Result: /c/Program%20Files/Adobe/Adobe%20After%20Effects%20CC%202015.3/Support%20Files/null/Scripts/ScriptUI%20Panels/Pr/C-Sh/fxs/Sample_01
    the null in between wont allow the path work correctly.
    Appreciate any suggestion.
    Vahab San replied 9 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
