Activity Forums Adobe After Effects Expressions How to link with relative values?
  • How to link with relative values?
    Posted by Mateo Mazzini on October 20, 2016 at 2:41 pm
    I have one object with position and scale animated, and I want another object to follow the position of the first object but not the scale, is there a way to link the position of the second object to the position of the first but in a relative way, as if were the “parent”?. Because if I put “thisComp.layer(“object1″).transform.position”, it copies the position of the first object, and I want it to retain it´s original position while following the parent.
    I know I can do this with a null object in the middle, but I think there must be a workaround on this, and I just don´t know it.
    thanks.
    Matz
    Dan Ebberts replied 3 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Romain Cousin
    October 20, 2016 at 3:19 pm
    I think you can write this expression on the position of your follower layer :
    thisComp.layer("NAME OF THE "PARENT" LAYER").transform.position+value;
    Freelance motion designer :
    http://www.romaincousin.fr
  • Dan Ebberts
    October 20, 2016 at 4:02 pm
    Try this:
    p = thisComp.layer(‘NAME OF THE “PARENT” LAYER’).transform.position;
    (p.value – p.valueAtTime(0)) + value;
    Dan
  • Romain Cousin
    October 20, 2016 at 4:22 pm
    Nice! I really need to learn how to use valueAtTime…
  • Mateo Mazzini
    October 20, 2016 at 4:39 pm
    Thanks a lot Dan! that does exactly what I needed.
    Is there a way to go further and make this expression work when you link at the middle of an animation?.
    I was playing with nearestKey(time) but I didn’t accomplish anything so far.
    Matz
  • Dan Ebberts
    October 20, 2016 at 5:43 pm
    If you wanted to attach to the parent at a particular keyframe, you could do it like this:
    p = thisComp.layer('NAME OF THE "PARENT" LAYER').transform.position;
    keyToStart = 2;
    if (p.numKeys > (keyToStart-1)){
    t = p.key(keyToStart).time;
    if (time > t){
    value + (p.value - p.valueAtTime(t))
    }else{
    value
    }else
    value
    Or, it you wanted to be at a particular time, you could do this:
    tStart = 2;
    if (time > tStart)
    value + (p.value - p.valueAtTime(tStart))
    else
    value
    Dan
  • Mateo Mazzini
    October 21, 2016 at 1:17 pm
    these two codes are amazing! thanks a lot Dan!
    Matz
  • Gustavo Saliola
    August 6, 2023 at 8:58 pm
    Hi Dan! As usual, and trough time, thanks for your kind and resourceful answers! In my case, I’m trying to parent paint clone strokes “clone position” and “position” to a null’s position, but maintaining both actual values, so I don’t have to manually adjust the paint work done.
    I know in my gut that it can’t be too difficult, but having googled for 2 hrs. and found myself here again, I think there’s hope.
  • Dan Ebberts
    August 6, 2023 at 11:00 pm
    I’m having a hard time picturing what it is that you’re asking. Can you provide more detail?
