Activity Forums Adobe Premiere Pro How to link separate audio clips to video clips?
  • How to link separate audio clips to video clips?
    Posted by Kesten Migdal on July 31, 2012 at 9:09 pm
    Newbie to Premiere Pro CS6, making the switch from FCP 7. I recorded audio on a separate source, then synced it to my original video/audio clips with PluralEyes. I unlinked my original audio and video clips by selecting Clip –> Unlink. I deleted my original audio clips and now want to link my synced audio clips that were recorded on a separate source. I don’t see a Clip –> Link option. That option only appears when you unlink your original audio/video clips and then want to link them again. How do you link a video clip and a separate audio clip? In FCP it was just Command + L for linking and unlinking. I tried Clip –> Merge Clips, but that just duplicates my clips and places them back in my project. Is there a simpler way?
    John-michael Seng-wheeler replied 9 years, 9 months ago 6 Members · 9 Replies
  • 9 Replies
  • Angelo Lorenzo
    July 31, 2012 at 9:48 pm
    Do you have the video and audio both selected? Are they both on unlocked tracks? You should have the link option.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Kesten Migdal
    August 1, 2012 at 5:28 am
    Okay, this was weird. I had both the video and audio tracks selected, but my only option was “unlink” even though they were never linked. I selected “unlink” anyway, then selected them both again and now have the “link” menu option available. I created the shortcut “Command + L” so it operates like FCP now. Still would be nice if you could link multiple clips at the same time, but that’s how it was with FCP too. I’m sure there’s a reason…
  • Dennis Radeke
    August 1, 2012 at 11:03 am
    The merge clips command you mentioned earlier is what you want to use. It essentially creates a virtual clip of both video and audio together and is specifically designed for double system sound.
  • Robert Fargo
    August 1, 2012 at 1:54 pm
    “Linking” multiple clips is best accomplished by simply nesting sequences.
  • John-michael Seng-wheeler
    August 1, 2012 at 4:31 pm
    That’s because the audio tracks were linked to each other. Once you unlinked them from each other, you could link all of them together with the video. I wish it wasn’t that way, but it is.
  • Guy Satchwell
    October 31, 2016 at 8:38 pm
    OK … I’m a MUCH newer newbie than the original poster with no previous experience of any editing …..but here I am staring at two clips. The original bit of video had an linked audio. that’s sitting in the timeline. I then took the audio recorded offboard on a recorder, took it into Audition, improved it ( lots of background noise ) and have imported it into PP. I then synched the new good audio to the video using merge by audio. Then unlinked the video from it’s original audio and threw the latter away. NOW ..as per the original poster I don’t know how to link the mute video to it’s new audio track. I can’t ‘select’ two tracks in the timeline can I ? So how do I merge them?
    October 31, 2016 at 9:07 pm
    Just select both clips in the timeline, right click, and select “merge clips…”
  • Guy Satchwell
    October 31, 2016 at 9:08 pm
    I don’t get how to select both clips in the timeline ..I only seem to be able to select one or the other ?
    October 31, 2016 at 9:09 pm
    Drag a selection around both of them. Or click one, hold shift and click the second.
