How to link many compositions to the same animation keyframes?
Here’s something I have been fiddling with the last few AE projects, and that I would really, REALLY like an answer to by now:
Let’s say we are creating a brief breaker swipe animation where a solid layer is quickly drawn across the screen. Easy enough: create a solid layer, and animate this layer with some nice, intricate adjustments to the speed graph. But what if I needed that breaker animation in 26 different colours and wanted to be able to adjust the motion of the swipe in a single place and not within the 26 color variation compositions? Also, I might have to go back and adjust the movement later, so I want those animation properties in one place only.How is that possible?
I tried: Putting all animation content into a null-object in a composition (called “Nice movement”). Then I created another composition called “Breaker color red” with the visual content. Into “Breaker color red” I added composition “Nice movement” and parented visual content to this composition. Does nothing.
A composition contains only keyframes in relation to visual content, and a null-object can’t link outside of the composition in which it appears. Right?
What have I gotten wrong? Need someone to look at this with kind eyes. Thanks so much.
