Activity Forums Adobe After Effects Expressions How to link certain keyframes?
  • How to link certain keyframes?
    Posted by Gabriel Silva on May 2, 2019 at 12:17 pm
    Sorry for google translator
    Hi guys, I need some help.
    I have a keyframe in position A and another keyframe in position B.
    I need to switch between position A and position B at a specific time in the timeline.
    Is there a way to make sure that when I change the two keyframes A and B, I automatically change the respective keyframes to A and B?
    Tomas Bumbulevičius replied 7 years, 4 months ago 3 Members · 5 Replies
  • Kalleheikki Kannisto
    May 2, 2019 at 1:01 pm
    Can you try and explain that in more detail? Right now it sounds like you are describing how keyframes work: If you switch (swap) keyframes A and B locations, you will get a reverse animation. That’s just how keyframes work. So the actual question, I gather, must be something different…?
    Senior Graphic Designer
  • Gabriel Silva
    May 2, 2019 at 1:47 pm
    Oks
    Oks! Here is the image:
    We have the red keyframes, they must be of equal value. I would like that when you change keyframe A, keyframes B and C are changed with the same values ​​of keyframe A automatically.
    May 2, 2019 at 3:37 pm
    Ok, I see. You can do so with expressions, but it is somewhat complex, since you need to tell the expression which keyframes should move (by index) and interpolate between fixed and adjustable keyframes between each keyframe pair.
    Here’s part of the answer, maybe 1/3 of the full expression needed, although this is slider-based value rather than keyframed. Similar idea though, except that you need to check both the previous and next keyframes at any given time. https://forums.creativecow.net/docs/forums/post.php?forumid=227&postid=30131&univpostid=30131&pview=t
    Keyframe value linking would be a nice feature.
    May 2, 2019 at 3:46 pm
    This tool might do it:
    https://aescripts.com/expression-timeline/
  • Tomas Bumbulevičius
    May 3, 2019 at 8:07 am
    If you select all the keyframes, hover on top of position transformation, and drag the position value, all keyframes are changes depending on the value change you make.
    Meaning, if you have two keyframes:
    A – 0px
    B – 100px
    Then click drag the mouse over the position transformation for X, within 50px, keyframes becomes:
    A – 50px
    B – 150px
    This will make sense only if you need to change it once.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
