Activity › Forums › Avid Media Composer › How to link 4k .r3d files / Composer 8.3
Felix Martiz replied 10 years, 6 months ago 4 Members · 14 Replies
Michael Phillips
February 10, 2015 at 4:39 pmThat should be fine – Source ID seems correct in both instances – Did you play around with the “relink to selected” options as well to see what combination works?
Felix Martiz
February 17, 2016 at 1:18 amHi there, I am truly having a heck of a time trying to relink my dmx files back to my 6k raw on Avid. I can really use your help because I am all out of ideas.
I got as far as the program relinking half of the files on the timeline only, not sure why this happened. Any help would be greatly appreciated.
thanks,
Felix
Michael Phillips
February 17, 2016 at 1:56 amNeed more info as per above – screenshots of master clips with Tape and Source File columns showing, and what is expected by the timeline. Are the the same name, different column?
Michael
Felix Martiz
February 17, 2016 at 2:56 amHello, thank you for your quick reply. In one folder I had the AMA link files, which i then transcoded to dmx files so that I can edit it on my slow computer at school. Now that I have a picture lock I want to relink the dmx files to the AMA Link files so that I can transfer the relinked timeline for grading. Any help would be very appreciated, thank you. below is the screenshot of the folder where I have both files, one ama link and the dmx file. The other folder is the relinked folder which has some files that relinked while others, like the one chosen, in limbo.
