Activity › Forums › Adobe Premiere Pro › How to link 4k files to proxies in premiere cs6?
  • How to link 4k files to proxies in premiere cs6?
    Posted by Piotr Bryl on January 22, 2015 at 5:44 pm
    After my first 4k shoot with GH4, I began with my typical 1920×1080 premiere pro workflow but found that my computer was lagging and kept stalling. I figured this was due to the large resolution of the 4k MP4 files, so I created 1280×720 mov proxies and then proceeded to cut my edit on a 1080 timeline using those proxies.
    I now want to replace the proxies with the 4k files so I can grade them, but when I do the typical offline then relink route, I’m told that the files don’t match and it seems to automatically just link the proxies instead again.
    As an alternative, I try to replace each proxy clip individually with the corresponding 4k clip, but when I do, it doesn’t recognize the position of the cut–rather it just replaces the footage at the beginning of the clip. This is obviously useless.
    My proxies are mov files while my 4k files are MP4.
    What do I do? I’ve been at this for hours and Im really stuck. Help! 🙁
    Piotr Bryl replied 11 years, 8 months ago 2 Members · 4 Replies
  • Ann Bens
    January 22, 2015 at 9:20 pm
    This is how offline editing is done.
    https://helpx.adobe.com/premiere-pro/using/create-clips-offline-editing.html
    Have not you tried it for a small project with a few clips if it will work?
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Piotr Bryl
    January 22, 2015 at 10:22 pm
    Thx Ann. I will test that workflow with my next project. But at this point I need to solve the problem I’m having. Any solutions?
  • Ann Bens
    January 23, 2015 at 5:57 pm
    The only option I can think of is import the 4K clips and manually Replace With Clip for each clip.
  • Piotr Bryl
    January 27, 2015 at 3:56 am
    I tried that but it doesn’t recognize the cut point of the proxy clip, so when I replace it, it just starts the clip from the beginning.
