Activity Forums DaVinci Resolve How-to limit effects to apply only to part of a timeline???
  • How-to limit effects to apply only to part of a timeline???
    Posted by Michael Mccune on December 14, 2015 at 5:29 pm
    Start with a video which includes a brief pan that includes a troublesome, overly bright or oddly colored elements within, say, a wall window showing the outside scene.
    OK. Use the qualifier to select that window with respect to HSL. OK. Use color wheels to make desired changes to the HSL selected bits. This also may unavoidably capture other elements in the frame.
    OK. Use a mask to restrict the qualifier to a limited spatial area.
    OK. The troublesome window now looks acceptable and the color changes are contained with that window.
    So far so good.
    But later in the timeline, these window, qualifier and color wheel adjustments show unintended side effects.
    OK. Just limit the temporal scope of these effects–the qualifier, the power window/mask and the color adjustments–to that short bit of the timeline.
    BUT HOW??? (Gotta happen every day for a professional and there probably is a keyword or name for this.)
    Razor-blade that short bit in the edit timeline??? Surely there is a smarter way.
    I have tried static keyframes as begin and end markers: then turn off the mask within that keyframe.
    OK. That may limit some but not all of the effects, such as color wheel adjustment.
    Any thoughts???
    Mike
    Michael Gissing replied 1 year, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • David Baud
    December 14, 2015 at 8:03 pm
    In Resolve you can apply color correction & FX to the whole track or clip by clip.
    In your case it sounds like you want to keep your adjustment to a clip basis. If you want to apply the same correction to the following clip, it is easy enough to copy your nodes and paste them to the new selected clip.
    HTH,
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • Michael Mccune
    December 15, 2015 at 5:27 am
    Actually the goal is to apply effects only to portions of a clip.
    Sorry, I was not clear.
    For example, if a pan within a clip captures an offending wall window with its overly bright light levels and prominent but uncomplimentary color elements, one can use a qualifier to manage that color and a mask to isolate the effect to that spatial area.
    But that effect remains throughout the clip.
    True, one can use keyframes to enter and end this mask effect within those keyframes. That is, turn off the mask. But the color effect does not turn off and it remains throughout the clip.
    The goal, then, is to play the clip to the point needing an effect, create and apply that effect only for the duration needed, and thereafter continue to the end of clip without that effect.
    Mike
  • David Baud
    December 16, 2015 at 7:02 am
    can’t you just keyframe part of the FX you want to change overtime? I am not sure what you mean by “color effect” but you can certainly keyframe any of your color adjustment, independently of your power window.
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
  • Glenn Sakatch
    December 16, 2015 at 8:25 pm
    does the window not remain for the entire clip? How long is this clip?
    Go to your keyframe area and select auto keyframe for that node.
    Go to your key page and adjust the gain of the matte to be either on or off during the shot.
    Glenn
  • David Curriston
    November 1, 2024 at 1:55 pm
    I have the exact same question. Trying to apply an effect to a portion of my clip only. I understand that I could simply cut the clip to achieve that result but… can I get what I want without cutting the clip?
  • Glenn Sakatch
    November 1, 2024 at 2:36 pm
    Same answer…either key frame your colour change from 0 to 100 to 0 again…or whatever it needs in your situation, or you can keyframe the opacity of that particular node to turn it off when not needed.
  • Michael Gissing
    November 4, 2024 at 1:38 am
    It sounds like you are set to use a remote grade not local. If you don’t want a shot grade to appear on shots later in the timeline then this may be what you are dealing with.
    This vid explains it https://www.youtube.com/watch?v=eBXrl5SGc6k
