Activity Forums Adobe After Effects Expressions How to limit a layer’s position to a circular zone
  • How to limit a layer’s position to a circular zone
    Posted by Romain Charles on May 7, 2018 at 1:13 pm
    Hi everybody,
    I would like to allow layer’s positions only inside a circle, as if the layer was linked to an invisible rope.
    It is easy to limit positions to a square with the function clamp(), but I can’t find a solution with a circle.
    How can I do ?
    Romain Charles replied 8 years, 4 months ago 3 Members · 6 Replies
  • Andrei Popa
    May 7, 2018 at 3:27 pm
    center = [960,540]
    maxDistance =100;
    if (length(center,position)>maxDistance) center + maxDistance*(position-center)/length(center,position) else value
    However, if you go too far outside, the layer will act a bit strange before you get its position back inside the circle. The code was taken from here and altered a bit to fit your situation.
    Andrei
    My Envato portfolio.
  • Dan Ebberts
    May 7, 2018 at 3:43 pm
    Here’s a way to do it with vectors:
    center = [500,400];
    radius = 200;
    v = position – center;
    length(v) > radius ? center + normalize(v)*radius : value
    Dan
  • Romain Charles
    May 7, 2018 at 3:44 pm
    Thank you very much, I spent my entire day trying to find a solution !
    You’re the best !
  • Romain Charles
    May 7, 2018 at 4:22 pm
    Thank you too Dan, that gives me the occasion to work my javascript 😉
  • Romain Charles
    May 8, 2018 at 2:48 pm
    Hello, this is how I used your expression to work better on duik rigging.
    I lock the controller on the members.
    The expression is applied to the controller position.
    Thanks to the both of you !
    // layers relationships : member C parented to memberB parented to memberA parented to control
    memberA=thisComp.layer("cuisse droite");
    memberB=thisComp.layer("patte arrière droite");
    memberC=thisComp.layer("mollet arrière droite");
    control=thisComp.layer("corps");
    function getWorldPos(L){
    return L.toWorld(L.anchorPoint);
    distA = length(getWorldPos(memberA),getWorldPos(memberB));
    distB = length(getWorldPos(memberB),getWorldPos(memberC));
    radius = distA+distB;
    // if the anchorPoint of the control layer is no [0,0]
    center = memberA.transform.position
    -corps.transform.anchorPoint;
    position = transform.position;
    v = position - center;
  • Romain Charles
    May 8, 2018 at 10:40 pm
    Update
    memberA=thisComp.layer("épaule droite");
    memberB=thisComp.layer("patte avant droite");
    memberC=thisComp.layer("mollet avant droite");
    center = getWorldPos(memberA);
    pos = getWorldPos(thisLayer);
    v = pos - center;
