Activity Forums Adobe After Effects Expressions How to know the value of the result of an expression?
  • How to know the value of the result of an expression?
    Posted by Tiago Cav on April 6, 2015 at 1:02 am
    I made a expression “wiggle” that was placed on solid opacity. Then the “wiggle” will create random values for opacity. Only I want to have this random “wiggle value” in the form of expression. To create a condition if / else.
    I want every time the “wiggle” make solid opacity equal to or less than 9%, the opacity be modified to 10% opacity.
    It would be something like this:
    wiggle (1,150)
    if (“wiggle value result”<=9) {
    opacity=”10″;
    Tiago Cav replied 11 years, 5 months ago 2 Members · 5 Replies
  • Dan Ebberts
    April 6, 2015 at 1:57 pm
    This would be one way:
    Math.max(wiggle(1,150),10)
    Dan
  • Tiago Cav
    April 6, 2015 at 6:55 pm
    Amazing! Very simple for who knows.
    Thank You so Much!
  • Tiago Cav
    April 9, 2015 at 11:47 pm
    Only a little question. Is possible use Math.max and Math.min in the same Wiggle?
    Thanks.
  • Dan Ebberts
    April 9, 2015 at 11:57 pm
    For a range between 10 and 120, for example, it would be like this:
    Math.min(Math.max(wiggle(1,150),10),120)
    but you could also do it this way:
    clamp(wiggle(1,150),10,120)
    Dan
  • Tiago Cav
    April 10, 2015 at 12:02 am
    Amazing.
