Activity › Forums › Apple Final Cut Pro Legacy › How to know if certain filter has been applied to all clips in sequence.
  • How to know if certain filter has been applied to all clips in sequence.
    Posted by Joseph Torres on December 19, 2013 at 7:25 am
    I am currently in post-production of a feature film of mines and I have applied a “mojo” filter to every single clip in the entire movie to give a certain feel to it. However, being that I put it on so many clips, sometimes I wonder if I missed a clip or two (this has happened in the past). Although you can tell when the mojo filter is applied to a clip, sometimes you can’t really tell depending on the brightness and location.
    What I want to know is, without having to go back and double clicking on every single individual clip to see if the filter is applied, is there a way to see the filter(s) for every clip in the sequence all at the same time? Or at least in an easier way?
    Nick Meyers replied 12 years, 9 months ago 2 Members · 1 Reply
  • Nick Meyers
    December 20, 2013 at 3:25 pm
    ANSWER 1:
    hit option command T
    OR hit the tiny blue & green button lower left of timeline.
    this will open a small view under each track.
    a blue line indicates a motion effect is applied,
    a green bar indicates a filter is applied.
    you cant see what type of folter or how many.
    ANSWER 2:
    open your first clip into the viewer, go to the filters tab
    hit the down arrow to move from clip to clip while staying in the filters tab.
    you;d have to do this track by track.
    nick
