Activity Forums Adobe After Effects How to “knock out” portion of blended shapes
  • How to “knock out” portion of blended shapes
    Posted by Shawn Romano on July 29, 2013 at 1:44 pm
    Hello. I’ve worked with AE for almost ten years now but I cannot figure out how to make this work:
    I have three shape layers of different colors, all blended with the “add” mode to create a nice pattern (see below and read on).
    These shapes’ rotation property will be animated. As you can see the center is pure white. What I would like to do is CLEANLY knock out the center portion so that I am only left with the outer shapes. I have tried duplicating this comp with a bunch of different blending modes in hopes of creating a matte source that I could use to knock out the center, but I was unable to find anything that works. I also tried using a luma key, which has yielded really ugly results, even with feathering.
    Anyone have any ideas?
    Thank you.
    John Cuevas replied 12 years, 10 months ago 2 Members · 3 Replies
  • John Cuevas
    July 29, 2013 at 3:13 pm
    What if you precomped the entire thing, then used a key to key out the middle color.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Shawn Romano
    July 29, 2013 at 6:50 pm
    Thanks. I did try this but it wasn’t a very clean key. Tried using luma matte and Keylight. Keylight didn’t seem to do anything when I chose white as the key color…
  • John Cuevas
    July 30, 2013 at 12:53 pm
    I used the basic Keying>Color Key and it worked fine. Are you working with gradients, I ask because you when you mix the 3 colors together in it should produce one color and that should be very easy to knock out.
    Thinkck.com
