Activity › Forums › Apple Final Cut Pro Legacy › How to keep the aspect ratio when burning?
  • How to keep the aspect ratio when burning?
    Posted by Jacques Dedoire on February 19, 2009 at 3:41 pm
    Hi everybody,
    I’ve just tried to burn my 17,6 GB .mov export file unto a DVD via ROXIO.
    Roxio did not recognized my 1024×576 proportions but actually resized the file into 720×576.
    I was using roxio because I didn’t want to have to go through the whole Compressor to compress my .mov file.
    Question: Can I fix this problem with Roxio?
    Do I have to use Dvd studio pro or Idvd?
    How can I fix this problem with those?
    Any help more than welcomed
    Michael Gissing replied 17 years, 7 months ago 3 Members · 2 Replies
  • Steve Eisen
    February 19, 2009 at 3:49 pm
    If you are making a DVD, use compressor to make a m2v and ac3 file. Use DVDSP to make your DVD. Build your DVD in DVDSP. Use Roxio Toast to burn your DVD.
    The steps are in the manual.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Michael Gissing
    February 19, 2009 at 9:45 pm
    720 x 576 is the correct frame size for PAL standard def. By creating a 1024 x 576 quicktime, you have a file that will correctly display as 16:9 on a computer.
    A PAL DVD requires 720 x 576 so Roxio is correctly changing the file back to anamorphic. If you want a decent DVD, you are better off making an mpeg2 file in Compressor, maintaining the correct anamorphic ratio.
