Activity Forums Adobe Premiere Pro How to keep project nice and clean. (probably easy)
  • How to keep project nice and clean. (probably easy)
    Posted by Anders Haavie on August 7, 2017 at 8:34 am
    I edit realityshows, and I am now working on a series with 30 episodes, collaborating with other editors.
    My workflow is to edit an episode, open a previously edited episode in the mediabrowser and copy some of the music/graphics etc from the timeline, into my new project. What happens is that all the files I copy end up in the root of the project which makes the projectwindow extremely cluttered with alot of files.
    Is there any way to set a folder as default import folder, so that all files copied from other timelines go there? (I know I could probably import timelines but that is not optimal the way I work now)
    Anders
    Xraid-Xserve-Xsan-Xeverything
    Andy Patterson replied 9 years ago 5 Members · 7 Replies
  • 7 Replies
  • Duke Sweden
    August 7, 2017 at 11:30 am
    Create a bin, open it, then import your stuff. I myself had been doing a hackneyed version of that but my latest project, I created sound, images, green screen etc. folders in the folder holding my assets, and the same in Project window. Then when I imported my sound effects I opened that folder in Media Browser, opened the sound effects bin in the Project window, and imported, etc.
    So in your case just create a bin called timelines, open it, and then import your timelines.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
  • Anders Haavie
    August 13, 2017 at 12:47 pm
    Thanks for the reply, but it is not quite what I am looking for. I want to be able to define a folder all my assets end up in when I copy something from a timeline using the mediabrowers.
    I work with big projects, and I can’t use the import function, cause that will make the project very very big.
    Anders
  • Shane Ross
    August 13, 2017 at 5:24 pm
    The next update of Premiere will address this. BOY was I happy to see that. Next version you can open multiple projects at the same time..and even LOCK them like Avid bins in a shared environment. And when you copy over a sequence, you won’t get media populating the project, just the sequence.
    Shane
    Little Frog Post
  • Anders Haavie
    August 13, 2017 at 5:30 pm
    Thats fantastic. Just a couple of more fixes and it will be just as good as FCP7.0 hehe.
    Where can I read about the next version of Premiere??
    Have Adobe released any more info?
  • Andy Patterson
    August 13, 2017 at 6:07 pm
    [Shane Ross] “The next update of Premiere will address this.”
    Do you know when we will get the next update? There are still some bugs in Premiere Pro CC.
  • Shaun Khan
    August 13, 2017 at 11:47 pm
    I believe three weeks, from last speaking with Adobe Support.
    Aim Higher
    https://www.fd1.com
  • Andy Patterson
    August 14, 2017 at 1:23 am
    [Shaun Khan] “I believe three weeks, from last speaking with Adobe Support.”
    The NAB 2017 update was a let down. I hope we get something really good this time around.
