Activity › Forums › Apple Final Cut Pro Legacy › How to keep Original SMPTE timecode AND export a compressed file?
  • How to keep Original SMPTE timecode AND export a compressed file?
    Posted by Isabelle Carbonell on January 23, 2010 at 4:28 pm
    Hi there to anyone able to pitch in,
    I’m a filmmaker that often does international work in other languages. I need to give movie files to transcribers and translators often. I used to “burn” FCP timecode generator (and compressor’s got one too) onto the movies I’d give my transcribers but that is a time consuming and stupid process.
    Quicktime now reads the original timecode (SMPTE) as a function (along with the normal 0 start and also 0 start frames). If you are a FCP user you know that getting a transcription in the original SMPTE timecode is much better because your Viewer (Preview) window in FCP works off of the original SMPTE timecode… not from 0, hence making it a hassel to read all the time transcriptions associated to the translations to enter subtitles.
    OK. Yall don’t need to know all that necessarily.
    Here’s what I need to learn: How can I EXPORT and COMPRESS original HD footage that contains the ORIGINAL SMPTE timecode, and RETAIN the SMPTE timecode in the newly compressed and small file.
    This file, ideally, I could send to my transcriber all the way in Qatar, India, or who knows where, where with their slow connection they can download it in time and give me the transcription with the smpte timecode.
    Thanks for any help, let me know if I should provide any more specs.
    Best
    Isabelle
    Morgana Benedetti replied 12 years, 2 months ago 9 Members · 19 Replies
  • 19 Replies
  • Walter Biscardi
    January 23, 2010 at 4:46 pm
    [Isabelle Carbonell] “Here’s what I need to learn: How can I EXPORT and COMPRESS original HD footage that contains the ORIGINAL SMPTE timecode, and RETAIN the SMPTE timecode in the newly compressed and small file.”
    All quicktime movies do retain the timecode associated with the original movie file no matter how much you compress them and even if you do an audio only file. We have transcriptions done all the time with quicktime files and the transcriber gives us back the timecode from the original clip. Our clips are compressed all the way down to 160×120 because she doesn’t really need the video, just the audio.
    You just drag the raw clip from your Capture Scratch into Compressor and compress that file. That has the original timecode from the camera. Your Transcriber then uses Quicktime Player to view the TC instead of the zero counter.
    Our Transcriber has software that includes a foot pedal just like the old tape transcription machines had so she doesn’t even have to type the TC in. She just hits the pedal and the TC is automatically stamped into the document.
    We’ve done something like 100 hours of transcriptions over the past two years for our continuing documentaries and haven’t had a lick of trouble with TC matching up.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Ben Holmes
    January 23, 2010 at 4:47 pm
    A quick trawl of teh intertubes drags this up – it’s free too:
    https://www.qtsync.com/qtsync.php
    See if that gives you a workaround – you cannot export clip timecode with a QT export in FCP…
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Ben Holmes
    January 23, 2010 at 4:49 pm
    Scatch my response – and thanks for the useful info Walter, this will definitely be used for our next batch of translations…
    Edit Out Ltd
  • Bouke Vahl
    January 23, 2010 at 4:56 pm
    [walter biscardi] “All quicktime movies do retain the timecode associated with the original movie file no matter how much you compress them and even if you do an audio only file”
    True if you use Compressor, NOT true if you use almost any other application to transcode!
    And be warned, Walter’s statement about audio only ONLY works if you put the audio in a QT, it will NOT retain TC if you render to Mp3, wave or Aiff.
    But MP3 is going to be big in this department. Sound Devices puts TC metadata in the Mp3 header, and more and more transcriptions applications (including mine) can read it.
    If interested, i’ll make something to stamp Mp3 with the original QT tc.
    (it’s a small job, and i’ll do it for free if there is a need)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Isabelle Carbonell
    January 23, 2010 at 5:19 pm
    Interesting.
    Okay, one thing I forgot to add. Since I didn’t need to do any editing to the original footage, I just loaded it straight into Quicktime and exported it FROM quicktime. (I wanted to keep working on a project inside FCP while it was processing, and its typically faster than Compressor)
    Not through FCP, not through Compressor.
    I’ll go ahead and try compressor and report if that worked.
    Thanks for all the fast replies from everyone!
    -Isabelle
    https://www.izaca.com
    January 23, 2010 at 5:40 pm
    Okay… it doesn’t work. Here’s my workflow (very simple).
    1. I have my original .mov files (when these are opened in quicktime, the option to select the timecode is available).
    2. I drag these into compressor and export the smallest .mov file possible (but I keep the audio good quality for transcribing purposes). Either way, it’s H.264 100kbps, and exports to a .mov file.
    3. Once exported I open the compressed file with Quicktime, and it doesn’t allow me to see the original timecode anymore.
    What am I doing wrong?
    Thanks again for all your help
    Isabelle
  • Ben Holmes
    January 23, 2010 at 6:00 pm
    Bouke – I think there’s a need. an mp3 would be ideal for transcription, and for when you want to avoid translators coming to you rather than emailing them the interview. In my experience, this question is often asked, and as good to know as Walter’s solution is, this would be better.
    Ben
    Edit Out Ltd
  • John Pale
    January 23, 2010 at 7:56 pm
    [Ben Holmes] “you cannot export clip timecode with a QT export in FCP… “
    There is an easy workaround though. Just export the clip using the compression of your choice, then drag it back into the browser. Double click it to load into the Viewer. Go to Modify/Timecode and add the correct starting timecode to the clip. Voila…a timecode track is now added and you now have a compressed clip with timecode.
  • Walter Biscardi
    January 23, 2010 at 9:19 pm
    [Isabelle Carbonell] “3. Once exported I open the compressed file with Quicktime, and it doesn’t allow me to see the original timecode anymore.
    What am I doing wrong?”
    No clue honestly. That’s exactly what we do here all day every day. In fact we retain the TC from the FCP timelines when we export from there.
    We retain the original TC on all our quicktime files generated through Compressor on our end. have done so for years now.
    Blog!
    Twitter!
    January 23, 2010 at 11:20 pm
    [John Pale] “[Ben Holmes] “you cannot export clip timecode with a QT export in FCP… ”
    There is an easy workaround though. Just export the clip using the compression of your choice, then drag it back into the browser. Double click it to load into the Viewer. Go to Modify/Timecode and add the correct starting timecode to the clip. Voila…a timecode track is now added and you now have a compressed clip with timecode.”
    THANK YOU. THANK YOU. THANK YOU.
    That worked, easy as pie, no issues.
    I really don’t know why it won’t export the smpte timecode but this workaround takes me two seconds so its no issue at all. Really thanks.
    Thanks everyone else for trying to help. Not sure what’s going on in the end.
    Best
    Isabelle
