Activity › Forums › VEGAS Pro › How to keep fast frame changes crisp looking as on original?
  • How to keep fast frame changes crisp looking as on original?
    Posted by Jaanus Henno on May 30, 2014 at 5:49 am
    Hi!
    I have some mp4 files recorded with a Samsung Galaxy2 smartphone.
    The problem I have is after editing and rendering I don’t get satisfying results in regards of how the video is changing from frame to frame. That is happening when some movement is present, it looks washed away. I tried different options and framerates, but still the same problem.
    I guess that’s an interlacing problem, I’m not so aware of all those little details.
    The source file is progressive, frame rate (Mediainfo) 24,474 1920×1280, AVC Baseline L4, 1 Ref frame.
    My output would be mp4 for youtube.
    John Rofrano replied 12 years, 4 months ago 3 Members · 4 Replies
  • John Bolton
    May 30, 2014 at 7:25 am
    Have to tried to turn off – DISABLE RESAMPLE – in the Event Properties?
  • Jaanus Henno
    May 30, 2014 at 8:09 am
    Holy cow, that worked! Thanks!
    Btw. Should I always disable it? Or is it just with certain files?
  • Jaanus Henno
    May 30, 2014 at 8:35 am
    Ok, I reply myself after studying the topic a little further.
    One answer from a forum:
    I disable re-sampling for the following:
    *speeding things up
    *want a stutter in slower speed
    *the “smoothness” looks bad when I slow something down and it’s better to have a stutter.
    I have one more question. Is there something intermediate or a way to actually control sampling? What I mean is to somehow be able to tweak sampling so that I can choose the best option between jerking frames and too much ghosting.
  • John Rofrano
    May 30, 2014 at 11:36 am
    [Jaanus Henno] “I have one more question. Is there something intermediate or a way to actually control sampling? What I mean is to somehow be able to tweak sampling so that I can choose the best option between jerking frames and too much ghosting.”
    No, there is not. Resampling is either on or off, on an event by event basis; there is nothing to tweak. The Auto setting use to work well in the days of DV but with HD formats it doesn’t do a good job so you need to manually control this. I wish Sony would fix it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
