Activity Forums VEGAS Pro How to keep anchor points the same
  • How to keep anchor points the same
    Posted by Melody Kang on June 16, 2016 at 10:33 pm
    I’m masking animation and was wondering what to do if there are two of the same frame (the picture) and I already masked one. How do I duplicate the same points?
    Russ Froze replied 10 years, 2 months ago 2 Members · 1 Reply
  • Russ Froze
    June 17, 2016 at 2:22 am
    If I understand the question correctly, a simple copy and paste should do the trick. Just select the key frames that need to be copied using alt or shift for multiple selections. Then use Ctrl + c to copy move to where they are desired and use Ctrl + V to paste.
    Russ Froze
