Activity Forums Adobe After Effects How to keep a mask still while moving a layer under it?
  • How to keep a mask still while moving a layer under it?
    Posted by Wilky Black on May 7, 2008 at 8:39 pm
    how do you keep a mask still while moving the layer under it?
    i’ve done it before and for what ever reason i can’t remember how.
    (say, you have a image moving up the screen, and you want to mask off the top third of the screen. the mask needs to stay stilly while the line moves up the screen and disappears.)
    please help restore my lost brain cells.
    thanks
    Wilky Black
    Darby Edelen replied 18 years, 4 months ago 3 Members · 2 Replies
  • Curious Turtle
    May 7, 2008 at 9:09 pm
    Use a mask layer on top, and set it as a track matte on the layer below. Now you can move and affect mask or fill layer separately.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Darby Edelen
    May 7, 2008 at 10:13 pm
    Ben’s technique is definitely more flexible, and I highly recommend it. However, if you ever need to reposition something ‘under’ a mask you can use the pan behind tool (Y) to do so. This keyframes both the position and mask shape so you can very quickly end up with a mess of keyframes, which is why Ben’s suggestion is usually better.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
