Activity Forums Adobe After Effects How to isolate yellow colour from footage
  • How to isolate yellow colour from footage
    Posted by Scott Green on May 3, 2012 at 1:57 pm
    OK, so I’ve managed to highlight a particular colour in my footage for this music video and turn it to yellow.
    And now what I want to do isolate the yellow from everything else to use as a matte/alpha. And also to add a glow and motion blur effect that affects just the yellow and nothing else.
    Can anybody give me any tips on how to best achieve this please?
    Thank you.
    Splurj | Creative Multimedia Design Manchester
    Mathew Fuller replied 14 years, 4 months ago 3 Members · 4 Replies
  • Scott Green
    May 3, 2012 at 2:13 pm
    I used Hue/Saturation to remove the colours that I didn’t want, then adjusted the Hue and Saturation of the colours that I did want to make the yellow?
    Creative Multimedia Design Manchester | S©tt Green | Splurj
  • John Cuevas
    May 3, 2012 at 2:30 pm
    One method would be to isolate the color channel(green) that is predominant in the hat and then use the effect Channel ->Set Matte to green channel. Adding some levels effects before and after also helps to isolate the color a little more.
    You may have to use a mask/tracking afterwards to remove unwanted stuff in the alpha channel. Here’s a quick example project: 4072_creatingalpha.zip
    Also, if you just want something to show up in there, place a copy of that layer on top. Put what you want to be in the yellow on bottom and change the transfer mode of the top layer to saturation.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Scott Green
    May 3, 2012 at 2:49 pm
    I imagine that I might also be able to use the Channel -> Set Matte technique to select the Yellow colour rather than removing the Hue/Saturation adjustments that I’ve already made to create a Matte from that?
    It’s worth a try I suppose.
    Thanks a lot John, I’ll give that a whirl later on and see how I get on, cheers.
  • Mathew Fuller
    May 5, 2012 at 4:33 am
    Why not just use Primatte or Keylight. Simply key out the yellow and use that as an inverse Alpha Matte.
    The higher they fly… the much.
    My Reel:
    https://www.youtube.com/watch?v=olElCddRiBg
