Activity Forums Creative Community Conversations How to integrate the FCPX Auto-Matching function into traditional workflow – Workaround
  • How to integrate the FCPX Auto-Matching function into traditional workflow – Workaround
    Posted by Clayton Burkhart on June 22, 2011 at 10:54 am
    Putting aside all the arguments against FCPX for the time being, the Auto-Matching function does look valuable.
    After paying close attention to the feedback on this particular function, it appears to be a strong addition for accelerating workflow.
    What interests me is creating a workaround that would enable me to spring back into my traditional Apple Color/FCP with the corrected files.
    Can I assume that I could simply output these generically corrected Prores 422 files from FCPX and integrate them back into my traditional FCP timeline? Would anything about the new architecture prohibit me from doing this? Gamma shifts, metatags, etc.?
    Feedback from new FCPX owners in particular would be appreciated as opposed to just responses “in theory”.
    Gary Adcock replied 15 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    June 22, 2011 at 12:47 pm
    You would have to export self contained QT movies from FCPX, import to fcp7, reedit, send to Color.
  • Clayton Burkhart
    June 22, 2011 at 1:00 pm
    Ok, so it’s classical.
    The only thing that would be a real pain is to do the reference shots in traditional FCP/Color workflow and export them as self contained 422’s to be used in the FCPX app, and then re-export everything back out once again self contained.
    Obviously, this is only convenient with complex grades or where this is a ton of matching shots which need to be graded.
    We will see on my next big project.
  • Jeremy Garchow
    June 22, 2011 at 1:09 pm
    At this point, it’s just not practical.
  • Hector Berrebi
    June 22, 2011 at 1:15 pm
    [Clayton Burkhart] “Obviously, this is only convenient with complex grades or where this is a ton of matching shots which need to be graded.”
    🙂 i wonder what project would be that hard to match traditionally that you would need this sort of workaround for it…
    i agree with Jeremy
    not that practical yet.
    Hector Berrebi
    prePost Consulting
  • Gary Adcock
    June 22, 2011 at 1:35 pm
    What about using FCPX as the File importer? Especially from DSLR or other media, often times it needs the most work color matching, then you could output color corrected ProRes for editing in FCP7.
    Color matching is then part of the data management and file conversion step.
    this works for smaller shoots or projects
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Chris Kenny
    June 22, 2011 at 2:07 pm
    [gary adcock] “What about using FCPX as the File importer? Especially from DSLR or other media, often times it needs the most work color matching, then you could output color corrected ProRes for editing in FCP7.”
    As with Final Cut 7, there is at present no particularly sensible way to automate exporting a bunch of clips in the timeline as separate media files.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • Clayton Burkhart
    June 22, 2011 at 2:10 pm
    [gary adcock]
    this works for smaller shoots or projects”
    Actually that makes a heck of lot of sense. I would then follow it up into traditional Color with my control surface for serious grading/tweaking.
    This for me would be the only practical reason for purchase at this point, but a very practical reason nonetheless.
    It is true that I much prefer the 5DtoRGB conversion to Prores 422 because it was of the only apps which does not use a quicktime engine for conversion. I find far less stepping and a little more dynamic range with it. But I could live with this idea.
  • Clayton Burkhart
    June 22, 2011 at 2:11 pm
    [Chris Kenny]
    As with Final Cut 7, there is at present no particularly sensible way to automate exporting a bunch of clips in the timeline as separate media files.”
    Bummer.
  • Gary Adcock
    June 22, 2011 at 4:29 pm
    [Chris Kenny] “As with Final Cut 7, there is at present no particularly sensible way to automate exporting a bunch of clips in the timeline as separate media files.
    stop looking for FCP7 style fixes, processing if far more powerful here
    Working on something else today. I get back later.
    gary adcock
    Studio37
    Chicago, IL
