Activity › Forums › AJA Video Systems › How to install Apple Uncompressed 10bit & 8bit codecs onto non-Kona Macs ?
  • How to install Apple Uncompressed 10bit & 8bit codecs onto non-Kona Macs ?
    Posted by Ben Cheng on July 20, 2005 at 9:22 am
    Hi
    I would like to find out how do we install the Apple codecs – both Uncompressed 10bit & 8bit onto Macs w/o the Kona LS or 2 hardware ?
    Thanks for your attention & time !
    Cheers
    Ben
    Walter Biscardi replied 21 years, 2 months ago 3 Members · 4 Replies
  • Walter Biscardi
    July 20, 2005 at 11:20 am
    The Apple codecs are installed with Final Cut Pro.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Jared Picune
    July 20, 2005 at 4:31 pm
    I don’t know if your supposed to do this or not, but it works. Search for this this file on your system FCP Uncompressed 422.component
    It can be found on your system drive Library>QuickTime>FCP Uncompressed 422.component
    Just copy it in the same location on the computers that you need it on.
    ONE NOTE: I have not tried this on a Tiger system, but I have done it several times on 10.3.x
    Hope this helps!
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Ben Cheng
    July 21, 2005 at 2:36 am
    Hi
    Thanks for the advice
    Wondering if there was a codec-only installer for non-Kona hardware + non-FCP Macs doing graphics + animation + compositing work
    I was setting up a Kona LS as a capture station for a graphics department, when I realised the other Macs which do not have Kona + FCP, do not have the Apple Uncompressed codecs
    Guess Apple will have to come up with a codec-only installer in this case
    Cheers
    Ben
  • Walter Biscardi
    July 21, 2005 at 11:32 am
    [Ben Cheng] ”
    Guess Apple will have to come up with a codec-only installer in this case”
    Just follow Jared’s advice above and you’ll be all set.
