how to inprove Ram usage %age when outputting in AEcs4
Hi there,
i’m curious to know.. i’ve been outputting my AE compositions without a problem thus far. i believe to be using my best possible render settings, multiprocessing, CPU allocation etc and have my renders going out at a steady 3frames per minute or so.however, when i see my rendering status; on my render window i notice that AE says its only using 14% out of the 4GB of ram i have allocated.
is this normal? i keep wondering if i can make AE use a higher percentage of my allocated ram therefore giving a lot faster outputs, or is it that the other 86% is already being used but just not for my output?
thanks
any info is appreciated
Os
