Activity › Forums › Apple Final Cut Pro › How to ingest ONLY parts of clips that I want off CF, not the whole card
  • How to ingest ONLY parts of clips that I want off CF, not the whole card
    Posted by Bruce Patterson on March 30, 2012 at 2:44 am
    Hi there,
    We do daily edits as part of our business and shoot on 5D Mark IIs and now 5D Mark IIIs. When we’re building out edits we want to insert a CF card, scrub clips, set in/out points in the clips and import only the footage that we need. Up until lately we’ve been using Log and Transfer in FCP 7 and it has been working perfectly.
    Last Friday we picked up our 5D Mark III and the file structure is different so we can’t use FCP 7 anymore. This may be the final straw for us to move to Final Cut Pro X.
    The problem I’m running into though is, that I can’t get the CF card reader to be recognized in the “import files from Camera” window or any other way so that I can scrub through the clips. I know I could just import all of the footage from each card but I really don’t want to do that because it slows down our entire workflow. Just like I did in FCP 7, I would like to pop in a CF card into the reader, scrub clips, set my in/out points and just import my selects. I haven’t found a way to do this in FCP X…am I missing something???
    Thanks in advance!
    Jeff Kirkland replied 14 years, 6 months ago 5 Members · 5 Replies
  • Tom Wolsky
    March 30, 2012 at 7:19 am
    You can import individual clips from the card. You don’t have to import the whole card.
    If you want to import parts of a clip, Andynick on the Apple forum explained how to cheat the application into using the camera import function when this is normally not used with this camera.
    Create a folder called VIDEO at the root level of a drive. Put your clips into it. Open the camera import window in FCP. Click Open Archive. Select the VIDEO folder and click open. The window will populate with your clips.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Tony Brittan
    March 30, 2012 at 11:25 am
    Try Magic Bullet Grinder?
  • Bruce Patterson
    March 30, 2012 at 1:26 pm
    Thanks Tom,
    I finally got it to work. My issue was that I was creating the folder in with the word video in ALL CAPS. When I just typed it out as “Video” it worked and I was able to select only the part of the clips that I wanted.
    Thanks again to everyone who helped out on this issue!
  • Ivan Barra
    March 31, 2012 at 1:26 pm
    So Bruce, if I’m reading this correctly, you are making a folder on your CF card reader and dragging the footage into that before transferring, right?
  • Jeff Kirkland
    April 3, 2012 at 1:15 am
    Just wanted to add, because it doesn’t seem to be made clear here or in the original AndyNick post that the folder doesn’t have to be at the root level of the drive. Putting footage in any folder named ‘Video’ and choosing ‘Open Archive…’ will let you import.
    Jeff Kirkland | Southern Creative Media
    video * audio * post * production
    Melbourne, Australia
