Activity › Forums › Apple Final Cut Pro Legacy › how to increase jpeg image file timeline?
  • how to increase jpeg image file timeline?
    Posted by Anandabrata Ghosh on October 22, 2008 at 12:44 pm
    I have imported a jpeg image into a sequnce of 25fps. Then i take my image to the timelin track. Originally my image is of 1 frame. The maximum that I can increase it to 2 mins after giving the IN and OUT in the source window.
    How can i increase the jpeg timeline for than 2 mins. Please suggest.
    Regards,
    Anand
    Anandabrata Ghosh replied 17 years, 11 months ago 3 Members · 5 Replies
  • Tom Matthies
    October 22, 2008 at 1:03 pm
    Under the Final Cut pull down menu>User Preferences>Still/Freeze Duration. Change the time to whatever value you need and then reimport your stills.
    Tom
  • Anandabrata Ghosh
    October 22, 2008 at 2:03 pm
    Hi Tom,
    Thanks for your inputs. I set the time as suggested by you. But still when i give the file the max in and out points and take it to the time line , the maximum time it gives me is 2 mins.
    I have made the pre and post roll values on preferences as 00:00:06:00 – 00:00:10:00. should i change that value as well.
    Please suggest.
    Regards,
    Anand
  • Kevin Monahan
    October 22, 2008 at 3:30 pm
    No, just change the duration in the Viewer before editing it to the timeline.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Tom Matthies
    October 22, 2008 at 4:17 pm
    You will also need to get rid of the old stills in your browser and then re-import them again to have them come in at the new length. Otherwise, in the viewer they will automatically have in in/out points set when you load them into the window. Just clear those out to get the fill length of the still you imported.
    Tom
  • Anandabrata Ghosh
    October 23, 2008 at 1:33 pm
    Thanks for your inputs. But my problem persists. I will try and detail it incase I am doing anything incorrect.
    I have opened a FCP session. I create a new sequence. Then I go to user preferences –> editing tab –> still/freez duration. Currently it is showing 01:12:00:00. I change it to say 03:12:00:00. Moment I tab out from the field t changes back to its original value.
    Please suggest what do I need to do change the value of the same.
    Regards,
    Anand
