Activity › Forums › Apple Final Cut Pro Legacy › How to import XDCAM footage.
  • How to import XDCAM footage.
    Posted by Zeliha Bozkurt on November 24, 2008 at 3:59 pm
    Hi I have never used XDCAM footage before. I need to transfer some XDCAM rushes onto Digi Beta. Would i have to send the rushes out of house to get this done OR could I import it into Final Cut then play it onto Digi Beta. if so
    is there an online document that explains this.
    Zee.
    Andrew Kimery replied 17 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    November 24, 2008 at 4:28 pm
    If you are getting the footage as QTmovies, just drop it in a 10b Unc or Proress sequence.
    Set “Render all YUV material in High precission YUV’ and “Motion Rendering: Best”.
    Same CC and the Nattress “Chroma Smooth/Sharpening 420” and at export will look as original DigiBeta.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Paul Campbell
    November 24, 2008 at 6:44 pm
    If the files are inside a BPAV folder, you might need to use the XDCAM transfer software to convert them before opening them in FCP. (Or can FCP open these natively?)
  • Tom Daigon
    November 24, 2008 at 7:34 pm
    I believe that I read that the newest FCP importer released on the reduser.com site supports Native as well as 2 flavors of Prores.
  • Paul Campbell
    November 24, 2008 at 7:43 pm
    Sweet. So long XDCAM transfer if that’s true…
  • Ben Scott
    November 24, 2008 at 9:42 pm
    the XDCAM log and transfer plugin is separate to the red log and transfer plugin
    both presuppose new intel mac and upgrade to new fcp 6.0.5 (at least the red one anyway)
    the xdcam only does ex
    xdcam 422 (using the sony transfer horror) is now supported in Apple color
    XDCAM still cannot be transcoded on ingest to Prores and is long GOP, making it a real pain if you ask me
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
  • Tom Daigon
    November 24, 2008 at 10:36 pm
    Sure it can. I just hook the HDSDI output from a playback deck (PDW-F70) to the HDSDI of my Kona 3 and transcode to Prores as I digitize.
    I realize this is not “Injesting” files, but it brings in the XDCAM as clips in a format I like to use.
  • Ben Scott
    November 24, 2008 at 10:44 pm
    and not get the advantages of a tapeless system? e.g. its tapeless
    its just seems odd that XDCAM is MPEG2 instead of AVC (h264 advanced) based codec and that it is long GOP and is a low data rate and needs to be played in like a tape
    yes you can play it in, so can every tapeless format you just need the expensive player (and which of these formats will be around in 5 years time)
    sorry for the rant just seems bit strange that XDCAM needs to be such a pain to get into a system
    or my site at
  • Tom Daigon
    November 24, 2008 at 11:49 pm
    After working on projects using the file injest and the digitize work flows, its clear to me that either way, I need to take the time to review the content to I can intelligently utilize it in edit.
    Instead of injesting the huge file, then transcoding it to Prores, then viewing for content (3 Steps), I prefer to digitze, convert and view content simultaneously (1 step). Much more efficient use of my time.
  • Andy Mees
    November 25, 2008 at 12:43 am
    Hi Zee
    You don’t mention the flavour of XDCAM you’re expecting nor the format it will be delivered on, nor any of the hardware specs of your setup … make’s answering your question effectively a little tricky. You’ve got a lot of answes already but all culd b right or all could be wrong depending on the missing info.
    Are these rushes coming to you XDCAM disc, on an SxS card, or on a hard disc, or…? Is the footage DVCAM, IMX, MPEG HD / HDV / EX or MPEG HD 422?
    If you’re receiving the rushes pre-imported to a hard disc will they already have been rewrapped to Quicktime files or just as raw MXF?
    If receiving on XDCAM disc, can we assume you have the necessary hardware for ingest, ie an XDCAM camera, deck or drive unit?
    What hardware do you have on your FCP system for output back to DigiBeta … or are you mastering a quicktime movie to be dumped to tape elsewhere?
    Cheers
    Andy
  • Andrew Kimery
    November 25, 2008 at 3:36 am
    [Ben Scott] “sorry for the rant just seems bit strange that XDCAM needs to be such a pain to get into a system”
    Personally I like that the XDCAM xfer software can be used stand alone from FCP. I can bring in a days worth of files in the background and not have to stop editing.
    -A
