Activity Forums Apple Motion how to import vector file to a Motion shape object?
  • how to import vector file to a Motion shape object?
    Posted by Alexlj on October 22, 2007 at 2:16 pm
    Hi everyone
    here is what i am trying to do:
    1. I have a typography created in Illustrator, saved in AI and PDF format.
    2. I want to import the vector into Motion 3 so I can apply particle emmitters on the shape.
    the problems are
    1. strangely My motion 3 does not import .ai file. all the .ai files are grey which is not click-able.
    2. so I have to import the PDF (saved in illustrator). then do the following steps:
    a) apply emmitter
    b) in the inspector, change shape value to geometry
    c) drag the imported graph into “shape source” box
    the box rejects the file.
    I want the particle to be emmited from the outline of the typography not from the rectangular image canvas.
    Can anyone advice please.
    Brac001 replied 18 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Mark Spencer
    October 22, 2007 at 3:30 pm
    You need to convert your illustrator paths to shape using this script:
    https://www.motionsmarts.com/downloads.html
  • Alexlj
    October 22, 2007 at 3:44 pm
    thanks
    I had tried it and it can only export simple paths.
    my vector contains some compound paths and groups which apparently that script can’t handle.
  • Steve Cardwell
    October 22, 2007 at 6:32 pm
    Hello,
    Make sure the text in your illustrator file is converted to outlines. When you save it as an .ai file make sure “Create PDF Compatible File” is checked, this will allow motion to open it.
    Once you have your .ai file in Motion and you’ve set up your emitter you need to set Shape to Image (not geometry), then set Arrangement to Random Fill and drag your .ai file in to the Image Source well.
    You may have to mess about with a few more settings to get it just right but this should be a start.
    Hope this helps.
    Steve
  • Brac001
    October 22, 2007 at 10:29 pm
    Hello
    I am following that threat and i have a similar question does anybody how to do that with multiple layers I have a logo which i want to import in motion as a layered file (just like in AFter effects)
    I tried the script but it only exports the first file do i have to export all 30 layers of the logo one by one and than assemble in motion
    hope somebody can help i posted a similar questions but no reply
  • David Bogie
    October 23, 2007 at 2:16 pm
    Adobe’s products are much better integrated. You will find this far easier to do in After Effects with a layered AI or PS file than in Motion.
    Umm, that’s what I have found. Mark Spencer or another powerful wizard may have better advice for you but I’d say the time wasted trying to force Apple’s Motion to correctly use Adobe’s files will be better spend simply firing up AE.
    Aside: I’ve never needed to animate 30 layers of some dope’s logo. Certainly some of those can be combined.
    bogiesan
  • Brac001
    October 23, 2007 at 2:24 pm
    Thanks for the answer
    Actually i found a way around. I made the AI file big in resolution then I exported the file as Layered PSD File and import that file as a Project (layered) into motion and i had all layers as seperate files in motion
    regards
  • Alexlj
    October 24, 2007 at 3:05 am
    hi
    thanks but if I set it to image it will not maintain the shape. It will be the an rectangular which is just the size of the image.
    what I want is the shape of the typography not the frame of the image.
  • Alexlj
    October 24, 2007 at 3:08 am
    did you get a shape instead of a rectangular?
    I have tried your method but I am still getting the particles emitted from the frame (rectangular) of the layered image
  • Brac001
    October 25, 2007 at 4:45 pm
    Sorry
    for just getting back to you i actually did not do anything in regards your questions . i was glad to get it in motion the way i wanted. I am not a full time editor .
