Activity › Forums › Apple Final Cut Pro Legacy › How to import REDCINE-X PRO .XML timeline into FCP
  • How to import REDCINE-X PRO .XML timeline into FCP
    Posted by Justin Viney on February 6, 2013 at 9:50 am
    Hey there,
    I have been trying to familiarize myself with the REDCINE-X PRO, FCP workflow with RED footage. I am playing with some 4K RED ONE footage and find myself running into trouble when starting an online edit. I couldn’t find my solution on the net since everyone seems to operate differently when it comes to RED workflows so I thought I’d ask the forum myself.
    My steps here are as follows:
    (Let me know if I am doing anything wrong.)
    – Import R3D files into REDCINE-X PRO
    – Export proxies (1280×720 AppleProRes(LT) with 1/4th Debayer setting)
    – Import and edit proxies in FCP
    – Export the offline edit out as an .XML
    – Import the .XML into REDCINE-X PRO and the R3D directories.
    – Export Timeline (allclips) as QuickTime Wrappers, generate FCP .XML enabled.
    – Import .XML in FCP
    Now here is where I run into my issue. The dimensions of the sequence are all incorrect and need to be rendered, despite the settings I choose when importing the .XML. I want my online to be in 2K but I am not sure how to do that exactly. I read to use Quicktime Wrappers generated in REDCINE-X to connect the .XML but doing so I can’t seem to figure out how to configure the resolutions and adjust the debayer settings.
    Thanks for your time.
    Justin
    Justin Viney replied 13 years, 7 months ago 2 Members · 2 Replies
  • Rafael Amador
    February 6, 2013 at 3:15 pm
    I’ve never worked with that stuff, but what i see is that in the upper still (Edit Preset), you have selected “1920 x 1080” (QT Wrapper), which is HD but not 2K.
    I guess you should set there 2K.
    rafael
    http://www.nagavideo.com
  • Justin Viney
    February 7, 2013 at 5:27 am
    Hey thanks for your response.
    All the settings appear to be locked when selecting QuickTime Wrapper.
