Activity › Forums › Adobe Premiere Pro › How to import old captured tapes from Final Cut into Premiere Pro
  • How to import old captured tapes from Final Cut into Premiere Pro
    Posted by Melina Kolb on February 29, 2012 at 5:12 pm
    Hi all,
    I switched to Premiere Pro CS 5.5 a few months back from Final Cut 5 and I need to be able to edit some of the old tapes I had captured in Final Cut. The problem is the .mov files I had originally captured are not importing into Premiere. I figured it was because I am missing a codec in Premiere to read those files. Is there a way I can convert those old files, get the missing codec, or will I have to recapture the tapes in Premiere?
    Thanks.
    Melina Kolb replied 14 years, 7 months ago 2 Members · 4 Replies
  • Chris Borjis
    February 29, 2012 at 5:35 pm
    what codec did you capture in Prores?
  • Melina Kolb
    February 29, 2012 at 5:46 pm
    The files are all using the codec DV/DVCPRO – NTSC, Integer (Little Endian), Timecode
  • Chris Borjis
    February 29, 2012 at 9:14 pm
    those should work in premiere no problem.
    what exactly are you doing and what’s the exact problem you see?
  • Melina Kolb
    February 29, 2012 at 9:23 pm
    I figured out what to do. Before when I was in Premiere and I tried to import my captured files (through File > Import), they were grayed out so I couldn’t select them. But when I looked at them through the Media Browser I was able to import them that way. Not sure why the first method didn’t work.
