Activity › Forums › Adobe After Effects › How to import multiple TIFF as a sequence
Posted by Jerry Romero on June 15, 2009 at 4:27 pmHi,
This might seem as nobb question, I’m trying to import multiple TIFF files as a sequence onto AE, The TIFF where created on a Pablo at 60i fps and need to import as a sequence onto AE to make a 50i fps sequence, but when I attempt to import I keep getting a (-43) error message.
Any help please or any other suggestions that might work better on FCP. Thanks in advance.
-Jerry
Fred Fabre replied 15 years ago 5 Members · 6 Replies -
Carl Larsen
June 15, 2009 at 7:33 pmJerry,
You should be able to import a file sequence into AE by simply invoking the file>import dialog box, navigating to your sequence, selecting any of the images, making sure the “sequence” option is checked and clicking ok.
If this is consistently giving you problems, you may have a corrupted sequence.
As an alternative, you may want to try opening the sequence in quicktime pro and then exporting a .mov to whatever codec you want to use in AE. In this scenario you’d go to file>open image sequence> navigate to your images> choose 5o fps> and then choose save as… from the menu.Then import the saved .mov into AE and continue working.
I hope that helps.
Carl Larsen
TelescopeMediaGroup.net
Jerry Romero
June 15, 2009 at 9:17 pmCarl,
I’ve been trying to do “Multiple Files” from the Import box, select one clip. TIFF Sequence box is checked starts to think and then I get an error -43. Is there another great way to convert 60i footage to 50i?
Thanks in advance,
-Jerry
Darby Edelen
June 15, 2009 at 10:36 pmMy guess is that you have at least 1 corrupt image in your sequence, however here’s another possibility:
How many images are in your sequence? If I recall correctly, AE is incapable of handling sequences with more than 32,768 (or so) images in them, which is irritating.
If this is the case then you’d have to segment the sequence into different directories and import them separately to work with them in AE. You could then place those sequences end to end in a pre-comp to have your entire sequence.
Also, if you’re importing many TIFFs as one sequence, you don’t need to use the “Multiple Files” import.
Darby Edelen
Jerry Romero
June 16, 2009 at 4:35 pmThey are RGB TIFF’s and I only have 2,900 frames, so I’m not even close to being at the maximum. I think that Darby might be right in that there’s a TIFF that is corrupted. In the mean time I used “Nattres” on FCP to be able to change the frame rate from NTSC to PAL. That’s what I was attempting to do on AE. If there’s a better way, please let me know… but I still want to know what AE isn’t cooperating, I even try to import just one file and it keeps on crashing.
Thanks in advance,
-Jerry
Fred Fabre
August 24, 2011 at 8:43 amIt could be a problem with the naming of the TIFF files, you can either try to rename all the files with a renaming tool or, in my case, I did import them by chunks of 999 and it worked.
