Activity Forums Adobe Premiere Pro How to import images into Premiere, please help
  • How to import images into Premiere, please help
    Posted by Brian Felsen on April 13, 2005 at 3:16 pm
    Hi all,
    I’m trying to import .tif image files into Adobe Premiere Pro, without using After Effects, but whenever I stretch the picture out on the timeline, it makes a nasty flicker when I render and play the movie. Please let me know the best way of importing an image into Premiere and stretching it to various lengths so it doesn’t flicker.
    Best,
    Brian Felsen
    info*at*brianfelsen*dot*com
    Brian Felsen replied 21 years, 4 months ago 3 Members · 3 Replies
  • Steven L. gotz
    April 13, 2005 at 4:02 pm
    I am confused as to what you mean by “stretch”. If you mean that you change the duration, OK.
    Have you tried using the Flicker Removal setting?
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Shaun999
    April 13, 2005 at 6:54 pm
    That has happened to me before and the way i got around it was to zoom and use the razor to cut out 1 frame and then i selected it and copy / pasted it for the duration i wanted. It worked fine but maybe there is a faster way.
    Hope that helps, shaun
  • Brian Felsen
    April 14, 2005 at 10:38 pm
    Thank you so much; I’ll try it tomorrow. I love Premiere but sometimes it’s weird! Thanks once again;
    Best,
    Brian
