Activity Forums Maxon Cinema 4D How to import image sequence to play it in me Cinema 4D scene?
  • How to import image sequence to play it in me Cinema 4D scene?
    Posted by Eugene Dalarov on April 29, 2009 at 8:23 pm
    Hi, there!
    I have a problem – digging in C4D I still can’t find the way to attach to the object not just one texture but a sequence of the images.
    The idea is to make a short movie played on the plain in C4D scene.
    Help! Help! Where is the helping hand?:))
    Don Daedalus replied 8 years, 6 months ago 3 Members · 5 Replies
  • Nolan Scott
    April 30, 2009 at 12:18 am
    Open a Material in the Material Manager and drag it onto the Plane / select the first image of your sequence and open it into the colour channel / in the Attributes Manager tick the image bar / select the Animation Tab / click Calculate / go back to the Material channel and select the Editor Tab / check Animate Preview / play your animation…
    Regards
    Nolan
  • Eugene Dalarov
    May 1, 2009 at 10:32 am
    Thanks a lot, Nolan! You’re great))
    The only problem now is to assign when sequence should be played in the scene. For instance, I have 50 frames sequence and I want to play from frames 151 to 200 in the scene.
    Maybe you know how to do it either?
  • Nolan Scott
    May 2, 2009 at 12:03 am
    Please, have a look in the Attributes Manager / Animation Tab / all timing features are there:
    Mode / Timing / Range Start / Range End / Movie Start / Movie End / Frame Rate.
    Regards
    Nolan
  • Eugene Dalarov
    May 2, 2009 at 9:13 pm
    I’ve got it.
    Thanks a lot for your help, Nolan. I appreciate it!)))
  • Don Daedalus
    February 20, 2018 at 10:06 pm
    Just drag a .mov or .png sequence into the material editor then drag that onto your object/surface
    -DHPD
