Activity Forums Adobe After Effects How to import every 20th frame
  • How to import every 20th frame
    Posted by Justin Mettam on October 11, 2013 at 4:06 am
    I generated my image sequence out of Maya and rendered every 20th frame. How can I bring this sequence into AE so it reads frame 1 for 19frames then displays frame 20 for 19 frames etc. Or alternately bring in a sequence and but them all up against each other, for example frame 1,21,41,61 etc all together to be a 16frame sequence.
    Currently AE puts color bars between fame 1 and 21 and 41 etc.
    Thank you in advance.
    Matthew Woods replied 12 years, 11 months ago 3 Members · 3 Replies
  • Justin Mettam
    October 11, 2013 at 4:13 am
    Well I just discovered setting my comp to 1frame per second will kind of do the job, but it still puts color bars between each shot. frame 1 looks good frame 2 is color bars frame 3 looks good frame 4 is color bars etc.
    Any other solutions ?
  • Erik Waluska
    October 11, 2013 at 8:00 pm
    I would suggest precomping the image sequence and putting that into another comp and time remap it to stretch it out.
    Erik Waluska
    EAWmedia
  • Matthew Woods
    October 18, 2013 at 8:35 pm
    Try checking “Force alphabetical order” when importing your image sequence. That should ignore the missing frames and treat it as a 16 frame image sequence.
    Need a quick break from motion graphics?
    Try my game Constellation at:
    https://www.paperdragongames.com
