Activity Forums Adobe Premiere Pro How to import bluray in Premiere?
  • How to import bluray in Premiere?
    Posted by Michi Schranner on February 27, 2011 at 10:27 pm
    Is it possible to import a movie from bluray to premiere?
    One year ago I made my first short movie in after effects. I rendered the movie directly to bluray. Now I want to put a part of the movie into my showreel, but I can’t find the After Effects file anymore. So my question is, whether I can import the bluray into premiere (CS4).
    Or is there any other way with CS4 to rip the bluray into a full HD file?
    Thanks for all advices.
    Enjoy the day,
    Michi.
    Dave Drop replied 15 years, 1 month ago 3 Members · 3 Replies
  • Ann Bens
    February 28, 2011 at 1:02 am
    Copy BD to HDD and go into the STREAM directory there you will find your movie, its a m2ts file. You can import this into Premiere.
  • Michi Schranner
    February 28, 2011 at 8:13 am
    Wow, thanks for your quick reply. Works perfect.
    Have a nice day.
    Michi
  • Dave Drop
    August 16, 2011 at 2:31 am
    I just got an external BD burner drive, and am taking it for a spin (no pun intended).
    Since I have not burned any Blu-ray discs from my own videos yet, I just grabbed a disc (Avatar) to see what the file structure is, if I can play it back, etc.
    I tried your suggestion above to pull one of the .m2ts files into Premiere Pro CS4. However, I get a File Import Failure window that says “Unsupported format or damaged file.” In addition to your post, Adobe.com says M2TS files are supported for import into CS4.
    Is the problem that I am trying to pull files from a store-bought Blu-ray disc into Premiere, and there is some kind of copy protection, or is there something else I am doing wrong?
    Thank you!
    -Dave
