Activity Forums Avid Media Composer How to import ALE without Avid Log Exchange
  • How to import ALE without Avid Log Exchange
    Posted by Orion Mccaw on May 17, 2017 at 7:25 pm
    Hey, I’m trying to batch rename a bunch of clips in a bin by exporting the ALE and changing all the names in Excel then going back into avid and importing the new ALE. I used to do this on Avid 7 when the Avid Log Exchange software still existed. I would do all my changes in Excel, open the Tab file in Log Exchange, paste the original header data, export it as an ALE, open Avid, and import the new ALE. It would work like a charm. But since Avid 8 EOL’ed Log Exchange I’m not sure how to get a changed ALE that Avid will accept.
    I’m just wondering if there is another way to batch rename that I’m unfamiliar with or if there is another way to save an ALE that Avid will accept. Is my only option to try to find an install of Avid Log Exchange?
    Orion
    Orion Mccaw replied 9 years, 4 months ago 3 Members · 5 Replies
  • Richard Sanchez
    May 17, 2017 at 11:14 pm
    There is a way to create a self contained version of Avid Log Exchange. I’ve done this because I use it all the time. In order to do this, you’ll need Avid 7 installed on a system.
    After MCv7 and Filmscribe (or Avid Log Exchange) are installed copy the Avid Filmscribe (or Avid Log Exchange) folder to a flash drive.
    Within this copied folder, right click on FilmScribe, show package contents, go to Contents/Frameworks. From the computer Copy the following directories from /Library/Frameworks (copy them- don’t move them..) to this directory:
    QtCore.framework
    QtDesigner.framework
    QtDesignerComponents.framework
    QtGui.framework
    QtHelp.framework
    QtMultimedia.framework
    QtNetwork.framework
    QtOpenGL.framework
    QtScript.framework
    QtScriptTools.framework
    QtSql.framework
    QtSvg.framework
    QtTest.framework
    QtWebKit.framework
    QtXml.framework
    QtXmlPatterns.framework
    phonon.framework
    This gives you a standalone copy of Filmscribe (or Avid Log Exchange), which even works installed from a USB key…. and will not interfere with an existing MC install
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Michael Phillips
    May 18, 2017 at 12:48 pm
    Yes, it’s a shame that they removed Avid Log Exchange without replacing all its functionality. Something I’ve blogged about in the past.
    When checking ALE’s, I use Textwrangler (or similar functionality) that allows me to see invisible characters in the file. The biggest problem when coming from Excel is additional TABs when there should only be one, and no carriage return after the last event. If you open an ALE you just exported for reference you can quickly see the differences.
    Michael
  • Orion Mccaw
    May 18, 2017 at 4:19 pm
    Hey guys, Thanks for the tips. I should mention that at the studio we’re running the Avid on a PC.
    @Richard: Do you know if there is a process for doing the same thing on a PC?
    @Michael: I think I read your post about this when I was looking into this issue. Definitely annoying that they haven’t replaced the functionality. Textwrangler appears to be Mac software, would Notepad++ work the same way? Also when you say ‘checking’ ALEs do you mean that you would go into Excel and make your changes, then bring it into Textwrangler and remove the extra formatting that excel adds? Or, do you do all your changes in Textwrangler?
    Thanks a bunch!
    -Orion
  • Michael Phillips
    May 18, 2017 at 5:05 pm
    Any text editing application that shows invisible characters to ensure proper tab, space, return. So there are most likely the same tools on a PC. As far as Avid Log Exchange, you should be able to download an earlier version of the installer from Avid and install ALE only.
    Michael
  • Orion Mccaw
    May 18, 2017 at 5:28 pm
    alright, thanks for the help!
