Activity › Forums › Adobe Premiere Pro › How to import a Premiere sequence into another premiere projects with cuts intact.
  • How to import a Premiere sequence into another premiere projects with cuts intact.
    Posted by Noland Orozaco on June 25, 2013 at 8:07 pm
    I have Premiere Pro CS5, and I’m running windows 7. I have two premiere files that I’d like to combine, so I open up one of them and I go to file>import and I select the other file. The problem is that when I drag the sequence onto the timeline, I only get one big block of film and audio. All of my cuts and edits and transitions are there, but I can’t select any of them because it’s just one big block. I wan’t to have the cuts and edits intact so I can modify them. Any ideas?
    Noland Orozaco replied 13 years, 3 months ago 2 Members · 2 Replies
  • Ann Bens
    June 25, 2013 at 9:01 pm
    Dont drag just double click on the seqeunce in the Project window.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Noland Orozaco
    June 25, 2013 at 9:03 pm
    Works like a charm. Thank you!
