Activity › Forums › Media 100 › how to import a M100 XML file into AE6 as a composition?
  • how to import a M100 XML file into AE6 as a composition?
    Posted by Carlos Azm on March 11, 2006 at 9:56 am
    I just recently upgraded to M100 version 8.2.3 and I have notice that now when I try to export a program to After effects v.6 I get a XML file. When I import the flie into AE6, all I get is a folder with all the clips but no longer a composition with the clips in the same order as I have them in the timeline in Media 100. How can I get them into a composition as before?
    Thank you for any answer
    Carlos
    Floh Peters replied 20 years, 6 months ago 3 Members · 2 Replies
  • Matt Short
    March 12, 2006 at 4:15 pm
    Are you importing as a composition or footage?
  • Floh Peters
    March 12, 2006 at 4:16 pm
    [carlos azm] “I just recently upgraded to M100 version 8.2.3 and I have notice that now when I try to export a program to After effects v.6 I get a XML file. When I import the flie into AE6, all I get is a folder with all the clips but no longer a composition with the clips in the same order as I have them in the timeline in Media 100. How can I get them into a composition as before?”
    There *should* be a composition somewhere within the folder with all the footage clips. Are you sure that there is no Comp in the folder?
