How to I create Karaoke text style?
Posted by Nit Ron on May 2, 2007 at 7:18 amJust wondering how these guys did https://www.weddingvfx.com/ in Vegas 7d. Can Vegas 7d really can do Karaoke style text? Anyone know any tutorial on this subject. Its very interesting.
Nit.
Dul Paijo replied 15 years, 7 months ago 3 Members · 4 Replies -
Laszlo Kovacs
May 2, 2007 at 7:29 pmHi,
a simple looking solution:
Create each sentence as graphic in two versions, a standard and a highlited one.
Place the highlited one on top of the other, and mask it out.
Animate the mask so that the highliting is timed properly.Hope I could help.
By(t)e
K.L. -
Nit Ron
May 4, 2007 at 2:42 amLaszlo Kovacs, thanks.
Guess what, Eduis 4 Pro can do it in RealTime on dual core!
Too bad Vegas has to rendered.dpsVelocityQ is the best. It can do it in Real Time and Very sharp text!!!!
Thanks.
Nit. -
Laszlo Kovacs
May 4, 2007 at 5:54 amHi,
and you’re welcome.Mind that my idea is just one possible solution, there may be
other good approximation of the problem.About RT:
Vegas is not designed to be realtime (however preview is almost
realtime in most cases), vegas is an editor.OK, you have to render that takes some time.
How much time does it take compared to time it takes to input
all the text, and timing the appearence?I guess a lot more times then then the acutal length of a song…
😉So, does it really matter if it’s rendered realtime or not?
I guess not.
I think the important differences may be in such details as
how easy you can achieve the desired result.
Don’t know edius nor velocityq, so I can’t tell which is better.But there are also lot’s of titlers used beside vegas, I can imagine one of them could be effective as well.
Maybe a look around worth…As always, for a taks choose the tool that fits the best.
😉By(t)e
K.L. -
Dul Paijo
February 13, 2011 at 3:24 amHello All,
i want to make karaoke style like this….
https://www.youtube.com/watch?v=NNKHNGpitFI&featureis it possible using Sony Vegas Pro 10?
for example :
Seems like it was yesterday
when I saw your face
You told me
how proud you were, but I walked away
If only I knew what I know today, ooh, ooh1st screen
2nd screen
You told me
3rd screen
You told me
how proud you were
etc….Thanks you for your help
