Activity Forums Adobe After Effects Expressions How to hide expressions in .aep file….
  • How to hide expressions in .aep file….
    Posted by Luis Garcia on November 17, 2015 at 11:30 pm
    Hi! I have a project in AE and I would like to send it to a person but I don´t like that he could see the expressions I have used to do it… Is possible to protect or hide the expressions in the aep file??
    Thanks in advance!
    Yoan Boisjoli replied 9 months, 2 weeks ago 4 Members · 4 Replies
  • Dan Ebberts
    November 18, 2015 at 12:50 am
    You can use the ExtendScript Toolkit to create a .jsxbin binary file from the expression (File > Export as Binary…), then you can wrap the file’s contents in double quotes and drop it in an eval() expression. The resulting expression will look something like this:
    eval(“@JSXBIN@ES@2.0@MyBbyBn……..”);
    A word of caution though–my experience is that you can end up taking quite a performance hit doing this, especially if the expression is complex.
    Dan
  • Xavier Gomez
    November 18, 2015 at 2:13 pm
    Tricky!
    I tried this on an expression designed for a text layer. And suprise:
    Had to use double eval otherwise…… 🙂
    Xavier.
  • Luis Garcia
    November 18, 2015 at 10:05 pm
    Great! I will try, I think that is the thing I need…. Thanks!
  • Yoan Boisjoli
    November 24, 2025 at 2:30 am
    I know this thread is pretty old, but I ran into the same problem recently. Dan’s jsxbin approach still works, but the performance hit can be pretty rough on heavier expressions.
    I needed something simpler for client deliveries, so I ended up building a small tool called Hugly. It doesn’t hide expressions completely, but it uglifies them enough that they’re not readable at a glance, and you can also beautify them again when you need the clean version. It keeps the comp running normally since it doesn’t rely on eval tricks or binary includes.
    If you’re curious, here it is: https://aescripts.com/hugly
    Might help someone else landing on this thread years later like I did.
