Activity › Forums › Adobe Audition › How to hear the first track and record the second meanwhile?
  • How to hear the first track and record the second meanwhile?
    Posted by Onur Aker on June 29, 2012 at 2:48 pm
    Hello i’m new to audition. İ recorded the first track than when i record the second i want to hear the first one while i’m recording. How i’m going to do that? Thank you.
    Angelo Lorenzo replied 14 years, 2 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    July 4, 2012 at 5:41 pm
    Are you using the multitrack mode? You Enable one track for recording, record it, disable recording, move to the next track and enable it for recording. As you record you will also hear the previously recorded track.
    If you do not have some audio hardware designed properly for audio recording you may experience latency up to a few hundred milliseconds. When you play back both tracks they may be slightly off beat and you’ll have to manually nudge them to match.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
