Activity › Forums › Adobe After Effects › How to have only effects show up but not the layer itself?
  • How to have only effects show up but not the layer itself?
    Posted by Rebecca Apodaca on November 5, 2018 at 7:02 am
    This question is really simple yet I can’t figure out how to do it. What I’m trying to do is have the glitchify plugin/effect which is on a video layer, by itself on a black solid. Just the effect but not the actual video/layer. It sounds complicated but I just want the effect to show but not the background video footage on the same layer. I’ve tried all blending modes and keying the effect out doesn’t look good either. Here’s a screenshot of my project.
    Albert Kowalski replied 2 years, 3 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    November 5, 2018 at 10:33 am
    If you make three copies of the layer, one without the effect and two with, you can blend the first two in difference mode and precomp the result. On that comp you get full black where there is no difference between the two layers. You can use threshold to pull out all the areas that have been effected and use the result as a track matte for the third layer with the effect on it.
    Senior Graphic Designer
  • Albert Kowalski
    June 4, 2024 at 9:38 am
    Hi, I am trying this attempt but not sure what the steps are:
    1) How the layers should be stacked? Which is on top, the middle, and on the bottom? Which one should have the effect on?
    2) What do you mean by “changing the threshold?”
