Activity Forums Adobe After Effects Expressions How to have multiple points follow separate paths while maintaining the same relative x position
  • How to have multiple points follow separate paths while maintaining the same relative x position
    Posted by Luke Shaw on May 22, 2020 at 7:34 pm
    I want to mimic a graph similar to this in AE ( https://mf.freddiemac.com/aimi/)
    What i mean by this is, I want to create a mouse cursor and be able to keyframe its position around in my comp and have those 4 points along the line follow the mouses x position but maintain the relative y position to where they are on their path. I have tried everything i can think of, but even when i almost got it working through code there is an offset in speed between each point. Essentially I could drag an object and all of the points would move alone with it, while following their path, but they would all move in the x axis at slightly different speeds offsetting each other
    Essentially I want
    Path 1
    Path 2
    Path 3
    Path 4
    Object 1
    Object 2
    Object 3
    Object 4
    Mouse Cursor
    Object 1
    x position of object 1 is equal to x position of cursor
    y position of object 1 is equal to the y position of path 1 relative to the x position of mouse cursor
    Object 2
    etc..
    Thank you so much to anyone who can help me figure this out
    Luke Shaw replied 6 years, 3 months ago 2 Members · 6 Replies
  • Dan Ebberts
    May 22, 2020 at 7:59 pm
    What do these paths look like (your link doesn’t seem to work)?
    Dan
  • Luke Shaw
    May 22, 2020 at 8:29 pm
    Terribly sorry about that. I attached an image to this reply and ill put the link in again to see if it works
  • Luke Shaw
    May 22, 2020 at 8:30 pm
  • Dan Ebberts
    May 22, 2020 at 10:10 pm
    It’s tricky, but if your graphs are true functions of x (no instances of multiple y values for the same x) you can probably do it with an iterative solution like this simple binary search:
    iterations = 12;
    L = thisComp.layer("Path 1");
    p = L.content("Shape 1").content("Path 1").path;
    xc = thisComp.layer("Cursor").transform.position[0];
    p0 = L.toComp(p.pointOnPath(0));
    p1 = L.toComp(p.pointOnPath(1));
    if (xc < p0[0]){
    p0;
    }else if (xc > p1[0]){
    p1;
    }else{
    lower = 0;
    mid = .5;
    upper = 1.0;
    for ( i = 0; i < iterations; i++){
    pCur = L.toComp(p.pointOnPath(mid));
    if (pCur[0] == xc) break;
    if (pCur[0] > xc){
    upper = mid;
    }else{
    lower = mid
    mid = (upper+lower)/2;
    [xc,pCur[1]]
    Bumping the iterations value should make it more accurate at the expense of rendering performance.
    Dan
  • Luke Shaw
    May 22, 2020 at 10:30 pm
    wow, thank you so much! I’ll try this out over the weekend and let you know how it goes!!
  • Luke Shaw
    May 24, 2020 at 1:49 pm
    Just wanted to followup and say this works exactly how I wanted it to. I cant tell you how much I appreciate your help with this, thank you again and enjoy the rest of your weekend!
