Activity › Forums › VEGAS Pro › How to Group 2 clips? (opposite of split)
  • How to Group 2 clips? (opposite of split)
    Posted by David Hunt on February 26, 2010 at 12:41 pm
    I have videos that are broken down into chunks due to file size (4GB chunks) and I would like to span them with a Pan/Zoom. Normally I just copy the coordinates of the Pan/Zoom to each clip. Is there a way to group the clips together so that I can apply a Pan/Zoom or any other effect to the entire timeline of that track?
    Instead of splitting 1 clip into 2, I want to combine 2 clips into 1.
    Theo Van laar replied 16 years, 7 months ago 4 Members · 4 Replies
  • Theo Van laar
    February 26, 2010 at 4:16 pm
    Grouping multiple events is easy: select all the events you would like to group en select in the menu: EDIT-GROUP-CREATE NEW.
    However, when you would like to add an effect to a whole track, it is easier to add the FX to the track instead of the individual events. You can add an FX to a track in the track-header. You can even add an FX to a whole project!
    To add the event pan crop tool to a whole track, it might be easier to add this track with multiple events to your main project as a nested project.
    Theo
  • Terry Esslinger
    February 26, 2010 at 8:13 pm
    Maybe you want your video divided into 4GB chunks? If not consider reformating your HD to NTFS from FAT32.
  • Rob Strobbe
    March 6, 2010 at 3:55 am
    If you’re using Vegas Pro, bump the files together edge to edge on the timeline and save this to a VEG file. Then crate a new project and drag that VEG onto the timeline. Vegas will treat it a single event, and you’ll be able to pan/zoom around it.
    Rob
  • Theo Van laar
    March 6, 2010 at 9:16 am
    ‘If you’re using Vegas Pro, bump the files together edge to edge on the timeline and save this to a VEG file. Then crate a new project and drag that VEG onto the timeline.’
    Thats exactly what I meant when I talked about nested files….
    Theo
